Autor Wątek: Rozwijane MENU w CSS  (Przeczytany 10297 razy)
Jostys
Reputacja: -3 Offline Offline
Wiadomości: 225
Kame_sennin ^^
« : 12.02.2013, 00:15:14 »
Witam mam pytanie , co do danego menu w css czy ma ktoś pomysł jak zrobić by było ono rozwijane ?
// Mam nadzieje ze dobry dział
HTML
<dl id="menudemo11">
<dd><a href="#">1st menu link</a><span class="pointer"><img src="img/menupointer.gif" alt="pointer" /></span></dd>
<dd><a href="#">2nd menu link</a><span class="pointer"><img src="img/menupointer.gif" alt="pointer" /></span></dd>
<dd><a href="#">another link</a><span class="pointer"><img src="img/menupointer.gif" alt="pointer" /></span></dd>
<dd><a href="#">the last link</a><span class="pointer"><img src="img/menupointer.gif" alt="pointer" /></span></dd>
<dt>navigate<span class="pointer"><img src="img/menupointer.gif" alt="pointer" /></span></dt>
</dl>
margin: 0;
padding: 0;
#menudemo11 {
list-style: none;
width: 100%;
height: 100%;
background: #000;
overflow: hidden;
position: relative;
#menudemo11 dd,
#menudemo11 dt {
font-family: arial, sans-serif;
font-size: 10px;
letter-spacing: 1px;
color: #fff;
float: left;
padding: 16px 0 32px 0;
margin: 0 -16px 0 0;
background: url('img/menushadow.gif') bottom no-repeat;
position: relative;
/* little something for IE */
display: inline;
#menudemo11 dd:hover {
z-index: 1;
#menudemo11 a {
text-decoration: none;
color: #fff;
line-height: 16px;
float: left;
padding: 0 16px;
border-bottom: 1px solid #fff;
outline: none;
#menudemo11 a:hover {
color: #4CCED1;
#menudemo11 dd .pointer {
display: none;
#menudemo11 dd:hover .pointer,
#menudemo11 dt .pointer {
display: block;
position: absolute;
z-index: 1;
left: 50%;
top: 32px;
width: 2000px;
padding: 3px 0 0 0;
background: url('img/menudots.gif') repeat-x;
#menudemo11 dt {
line-height: 16px;
padding: 16px 16px 0 16px;
color: #4CCED1;
background: none;
display: block;
border-top: 1px solid #4CCED1;
padding: 2px 0 0 0;
background: none;
z-index: 2;
#menudemo11 dd img,
#menudemo11 dt img {
display: block;
border: 0;
position: relative;
left: -3px;
#menudemo11 dt:hover img {
display: block;
« Odpowiedz #1 : 12.02.2013, 19:30:50 »
Co znaczy rozwijane? Chodzi Ci o animację tego? Może po prostu znajdź gotowe CSSy do rozwijanego menu - jest tego pewnie trochę na sieci.
Jostys
Wiadomości: 225
Kame_sennin ^^
« Odpowiedz #2 : 13.02.2013, 12:09:50 »
Zimosław chodzi mi o coś takie by po kliknięciu/najechaniu kursorem zjeżdżało w dół .
Przykład
« Odpowiedz #3 : 13.02.2013, 18:55:00 »
Na tym twoim przykładzie też się nagle pojawia podmenu, tak jak w Twoim kodzie.
Gacko
Wiadomości: 635
« Odpowiedz #4 : 13.02.2013, 20:23:17 »
Jostys - jeżeli chcesz by zjeżdżało, a nie pokazywało się natychmiast, to musisz to jakoś zanimować. Są kilka sposobów na to - CSS3 (CSS2 tego nie ogarnia) lub jQuery bądź Flash.
« Odpowiedz #5 : 13.02.2013, 23:16:29 »
Javascript wystarczy, nie trzeba Flasha. Ale czemu tak wzbraniasz się przed znalezieniem czegoś gotowego?
Jostys
Wiadomości: 225
Kame_sennin ^^
« Odpowiedz #6 : 14.02.2013, 11:58:48 »
Ziomosław emm gdyż to pasuje mi idealnie do strony chociaż by i dla tego , po 2 jak by ktos mi tu raz podpowiedział mógł bym z tego się czegoś nauczyć .
Dobrotek mógł byś jakiś sposób zapodać ? (do CSS3)
Gacko
Wiadomości: 635
« Odpowiedz #7 : 14.02.2013, 16:54:56 »
Jostys - na moje oko wystarczy http://www.w3schools.com/css3/css3_animations.asp
Tylko musisz parametry pozmieniać Mrugnięcie CSS3 jeszcze nie jest aż tak dojrzały, by obowiązywał jako standard tak jak CSS2 (albo mam przestarzałe info).
Żeby zobrazować jak działa takie animowanie, polecam zerknąć tutaj:
http://www.css3maker.com/css3-animation.html#
Jeżeli to nic nie pomoże, zerknij sobie do tego tuta:
http://www.red-team-design.com/css3-animated-dropdown-menu
Facet w przejrzysty sposób wyjaśnia co i jak ustawić.
Jeżeli ten komplet Cię nie satysfakcjonuje, polecam poszukać pod ogólnymi hasłami jak: CSS3 animation hover menu
i innymi kombinacjami wyrazów Mrugnięcie
Powodzenia!
Polskie Forum Użytkowników GIMP-aOgólne dyskusjeDyskusjeWebmastering & WebdesignWątek: Rozwijane MENU w CSS
